Canadian Bender Dealer
ReaperSRX
New Liskeard, Ontario
I have a bender can that i would like to repack, are there any Bender dealers in Canada so i can get the repack kit..........i have have also read in the past of guys using just normal motorcycle exhaust packing which is cheaper, but not sure on the quality compared to Bender's kit (which just might be the same stuff just marked up)..............James
Gerry Prosser runs the Bender Canada opporation, you may want to call Bender @ 585 937-6829 and ask for Gerry's #.
No need to use the bender kit, just get a sheet of Moose packing and cut it down. Less Than six bucks USD.
Bender Stinger Re-packing ?
I would like to re-pack my bender triple stingers. It appears that I would have to grind off the three tack welds on the top to remove the packing. I would then have to re-weld them back on. Is this the correct way to do this?
Thanks for the other bender info guys.
