VmaX 600
Just like title says has anyone tried to put any shocks from a SXR or Viper on there SRX? If so whats it take to do it?
WNYViper
Do a search, many people have done it with positive results... you will need the Viper shocks, limiter straps, and transfer rods... and probably a re-valve on the shocks depending on the donor sled...
(under edit, its after 12am, so all validity of this post is null and void...)
skid swap will be better...............................................................and cheaper........................
VmaX 600
Whammy said:skid swap will be better...............................................................and cheaper........................
Ahh sorry I meant to ask about the front shocks. As for rear I would like to try and find a Edge suspension.
JeepJimmy
BeTheViper used to make brackets. he apparently isntonline much this year. i been trying to find a set of his upper front shock mounts to use VIper shocks in the front of my srx. but havent had any luck.
JERSEYJOE
Ski Swap
I Did Both On My 2001 Srx. Viper Skid With Ohlins And Stock Viper Front Shocks With Betheviper's Brackets.
Some Folks Say To Use The Srx Upper Shock Mount And Mount It Upside Down. Also Involves Cutting Access In The Belly Pan. Both These Mods Together Are Worth The Money And Time Imho.
VmaX 600
JERSEYJOE said:I Did Both On My 2001 Srx. Viper Skid With Ohlins And Stock Viper Front Shocks With Betheviper's Brackets.
Was there anything else you had to do on the front end?
JERSEYJOE
Front End
I Installed A Wide Fit Also
VmaX 600
JERSEYJOE said:I Installed A Wide Fit Also
Did you just use longer radius rods?
780srxgeorge
ther is a guy on ebay selling brackits 4 long travle. go on ebay punch up srx an u will see the front of a 01 srx.it dont give u long travle it raises the bottom of the belly pan up 3 to 4in.for about $40.i bought a set 5 or 6 yers ago great investment!
