Can Someone tell me what the easiest way to remove a starter form a 99 Vmax with a 600 tripple. I'm having a bugger of a time removing the starter bolt from the clutch side of starter. Very tight area!!
OnDaTrail
I'm going on fuzzy memory here, but if I remember right, I pulled the clutch and could see that bolt through a window in the aluminum. It allowed be to guide the socket on with my finger.
Thanks, I figured the clutch had to come off to get that lower bolt.
bzktm8
removal
You also will need to use a box end to break it loose, and the open end to get the the bolt out. Working without the clutch, makes it allot easir to see and reach.
