02 viper ?s
1995vmax500le
arnprior ontario canada
just wondering if i can use stainless bolts as a replacement for the steel exhaust manifold studs on my viper.
also need to know how and where to reroute my carb vent lines as i want to vent them to the atmosphere instead of the air box.
last but not least should i reinforce the steering stem since it would be eay to remove at the moment. it is not broke or anything but i have read that they do crack and i ride agressively and have the bars raised 5" and pivoted forward about 2". i just dont want to have to deal with it later if i can do it know
yes, you can use a stainless bolt instead of a steel stud to hold manifold on. also, why do you want to switch from vented to airbox, to the atmosphere? got pipes on that thing? if you choose to vent to atmosphere, just zip tie up the hoses neatly to the carbs and you'll have to drop jetting to like 147.5 mains then.
