did they offer a 95-96 v-max xt with a 136" track ?
Yes I think they did.
sandmaster
yup have one here also has a two up seat on it too, its the wifes sled
i know they offered the regular v-max in a 136" in 94 but i cant find anything on the 95-96 xt. am i correct in thinking the rails are diffrent from the v-max to the v-max xt.
ok thanks guys , now i have to find a set of rails......
sandmaster
xt's do have differnt rails there the first version of the proaction suspention
sandmaster said:xt's do have differnt rails there the first version of the proaction suspention
ok narrows it down to i need 95-96 xt 136" rails. thanks every1.
No they did not offer a 96 XT(the only year for a pogostick XT) with a 136" track. Sandmaster is correct, it was the first year for the pro-action suspension so you may be able to use rails from a newer 136" pro-action skid.
i pretty sure the 94-96's came with a 3/4" lug , will a 1" lug fit in these ?
it will fit right in. about 1 3/16 is max without a driver changeout. drop to 8t and you can almost do 2". put a bunch of the .92 (7/8" ish) in to those chassis with no issues.
so a 1" track with studs is cuttin it close without changing drivers ?
not committing to the studs, as we dont run them out here, but if your front heat exchanger is protected, you should be good to go. 94-96 tunnels were the same, xt had way more travel with the p/a skid, but the chaincase and drivers were the same location. if the skid and track is still in there, mock up a stud and spin it through. pay close attention at the bulkhead area. thats where the issue lies. i do have a driveshaft with 8t drivers for that sled,non extrovert, if you need them. make you a good deal. Joe?
yeah.... windshield looks smokin
. thanks again. kickin around some diffrent ideas with this sled. just replace the 121 , or stretch it to 136... i can get a set of 98 136 rails and a track , but dont know if the 96 xt parts will swap over.
man, i just sold that 136 p/a skid awhile back, from a 97 vmax 4 mountain. would have been the same as what your looking for. i would bet the 98 rails are real close. i think they were the same until 99. run a microfishe check, like you probably already have and see. a good cross reference i use is yamahasportsplaza.com, i think(without looking at the favorites). run through the rigamarole for the part your looking for, jot the pt# down(or cut and paste as you computer know hows do), enter into the parts look up side and it will show you every model that part interchanges with. good luck.
BARON 8BU
snowdad4 said:man, i just sold that 136 p/a skid awhile back, from a 97 vmax 4 mountain.
What happened to the rest of the sled?
good question. under hood fire apparently. when i got it it was just a carcass, bulkhead, struts, tunnel, and skid. sold the bulkhead and struts to someone that made a trailer out of it, why i dont know. finally scrapped the tunnel. had too many leaning against the wall. kinda sad really, if i only new then what that sled could have been worth.
BARON 8BU
O.K. after hearing the story feel like i could puke. and it's not even my sled.snowdad4 said:good question. under hood fire apparently. when i got it it was just a carcass, bulkhead, struts, tunnel, and skid. sold the bulkhead and struts to someone that made a trailer out of it, why i dont know. finally scrapped the tunnel. had too many leaning against the wall. kinda sad really, if i only new then what that sled could have been worth.
blk04700,
I would just by a set of extensions for your P/A suspension and a 136" track. You probably will have to get a different rear cooler and a tunnel extension also.
is it my imagination or are the 94-96 tunnels over an inch wider than 97 and up ?
sandmaster
not sure but i have a bare tunnel i can measure if you would like ?
i picked up a front pivot shaft i found in the garage and went to go stick it in my 97 thinking it went to that sled and it was too long. ended up checking it to my tunnel from my 95 xt and it fits that one , so i guess starting in 97 the tunnels are about an inch narrower.
