rx1jim
What should the squish dimension be when using a piece of solder to measure it on a 2000 SRX? My sled (2nd owner) has 2 heads from a 2000 SRX and one head from a 99 SRX. Thanks!
WNYViper
Quoting Don, MrViper700... "The 2000-02 srx usually have .060-.063" stock" from this thread...
http://www.totallyamaha.net/forums/showthread.php?t=11494&highlight=aftermarket+head+squish
to be safe for pump gas the lowest you want to see is .052-.055
rx1jim
Thanks for the reply and the info.. I need to get some thick solder wire and check my engine.
staggs65
i thought the 98-99 heads were different from 00-02
WNYViper
staggs65 said:i thought the 98-99 heads were different from 00-02
They are... I was thinking about that this evening, Im wondering if the previous owner didnt trash a cylinder/head then when he rebuilt it took it to get ported and they fly cut a 99 head to match the 00 heads... (pure speculation, and I think you said it was trail ported in another post, so thats my thoughts)
