whats everyone use? any preferences? its about time to change my chaincase oil and im just wondering...its got yamaha oem chaincase oil in it now, any difference if i change to amsoil series 2000 synthetic?
unchained
I use ATF
kirk700 srx
I use 75W90 synthetic gear lube
OnDaTrail
I use Amsoil chaincase oil.
ryanryan
Chaincase oil from Canadian Tire, I think it is shell or something like that.
staggs65
any one try this
X2 on the Amsoil chaincase oil.
I'm starting to like the idea of Mrs. Butterworth's though....
Yamanewf
Amsoil synthetic ATF.
hereismylife
me to
me to
you guys using the ATF: Do you change it more frequently or just once a season? I ask because I already change the my oil at the beginning of every season using synthetic 75w90 Motomaster stuff (the bottle goes a long way for $10). I put on about 2500-3500 KM. Would consider the ATF if I felt sure it will run that long......
Triple X
crewchief47 said:you guys using the ATF: Do you change it more frequently or just once a season? I ask because I already change the my oil at the beginning of every season using synthetic 75w90 Motomaster stuff (the bottle goes a long way for $10). I put on about 2500-3500 KM. Would consider the ATF if I felt sure it will run that long......
I'am with you crew, I run the same stuff (gold bottle). I used to use synthetic ATF in my drag sled, it was good for 500 feet at a time but for all winter long, I like 75W90.
Better stick with the gear lube-seems more suited to the application. Whats the advantage of using ATF?
Lighter weight-less drag?
rx1jim
I use Amsoil synthetic chaincase oil in all my sleds. I believe the ATF fluid will work fine also. Many manual truck transmissions and transfer cases use ATF as the lube. I just changed the lube in the transfer case on my Ford F250 truck. The manual specifies Mercon V ATF.
