turks clutching
romig
pa
I have a stock 03 sx viper would like to buy the clutch set up of turks that everyone says about were can i buyall the parts and how much!!!
I really have no idea just some thing better than stock i guess that turk has a set up ?
Go back out to the home page, click on technical pages, then snowmobile tech, then CLUTCHES and Jetting. Scroll down to Clutching Tuning & Jetting Page. While you are in tech pages, read, read, read. There are two setups listed for your sled. One for trail riding is very simply to swap out your helix and secondary spring. You can purchase them from your Yamaha dealer. The helix is p/n 8FA-17604-00-00 and costs about $100 depending on where you buy. The green spring is p/n 90508-556A2-00, about $20. You could also look for used.
Most of Turks setups use OEM yamaha weights, so get those from Yamaha. He has also done some setups using Heel Clickers and you get those from SuperTorquer.
Would help if you posted the setup you are interested in.
