yamalars
Going 780 soon and have to make me a MEGA low buck clutchsetup!
Have stock dn20's now with 4,5g in each hole and stock spring and a hauck 51/43 cam with a silver spring.
My plan is to try keep both the weights and cam for now? (untill i get rich =)
And just swap the spring to a blu/wht/blu witch have the same preload but a bit lower rate.
So what's the experts say abaout this?? PS. Stage 1 cpr 780 kit with stock pipes and carbs to start with and 23/40 gearing. Thanks!
get some 5.5 or 6 gram boldts from hauck powersports.Go to a green sec spring.
yamalars
Ok! Will do that. Thanks for the input!pro116 said:get some 5.5 or 6 gram boldts from hauck powersports.Go to a green sec spring.
Maybe i'll try the recomended 53/47 cam later when i can afford it.
But i'll start with this and see how it works?
