Just put a set of Fox Floats on my SRX. Was wondering what a good psi setting would be? 125psi? higher or lower?
Sledsquatch
- Sep 29, 2008
- Carleton Place, Ontario
- www.simplifiedaudiovideo.com
Not sure on the psi but I have heard it is a very good idea to get protectors for those shocks, apparently once they are dinged slightly they lose air pressure real easy.
i only had 50 psi in them on my rx1 and seem to work ok
remember to have the front of the sled off the graound to air them up so all pressur is off the skis....... My buddy just runs them with around 20 pounds on his Apex RTX............ I would think at 125 thay would not move.
T.S.U.Filmz
i run 100-125 with no sway bar works great on my SRX
03sxviper
What sleds come factory with these shocks, and how much to buy aftermarket?
staggs65
snopro cats, probably othersWhat sleds come factory with these shocks
I bought a set new for an 09 Phazer RTX for $400
03sxviper said:What sleds come factory with these shocks, and how much to buy aftermarket?
AC Sno Pro F6, F8, Z1 Turbo and the CF 8 Sno Pro. And for Yamaha, Nytro RTX/(SE comes with Float X) and Phazer RTX and the discontinued Apex RTX all come with Fox Floats.
Don't forget the Apex Mtn SE came with Fox Floats in the front also.
wish i could put a set on my viper what is needed to do it? anyone have a write up on it?
xviperx7 said:wish i could put a set on my viper what is needed to do it? anyone have a write up on it?
There was a thread on here a couple days ago and one of the members was saying that he just put Fox Floats on his Viper.
Try doing a search...
T.S.U.Filmz
the Viper mounts on the top are different
orchie18
Anyone used floats from an apex, on there SRX, direct bolt up or modifations to mounting brackets?
I have a sent of fox float evol r shocks on next new condition i would be willing to sell if anyone is interested 800. Pm me
I have a sent of fox float evol r shocks on next new condition i would be willing to sell if anyone is interested $800. Pm me tgey are 16.8 inches long by the way. Came off an arctic cat.
livewire_101proof
My 06 rsnytro with floats called for 70psi stock so I would think starting close to that and fine tuning your ride height, handling, transfer...
There are shock mounts out there for vipers to use regular style shocks. The ends on Phazer shocks are narrower than some others and fit fine in the mount on the trailing arm. Not sure on the cat ones.
srxhair
I have the phazer fox shocks on my 151 srx set at 60 lbs. the front is lifted about 4" higher than stock with no sway bar. I also had to extend the mounts on the steering arms with bushings so the steering does not lock up when the skis are in the air.
burnoutink
I run 60-80psi Fox Evol X on my Apex MTN, when solo riding and to take extra impact from cliff drops, and when I double standing up side by side for snowboarding usually 100-120psi.
I think this works good for my style of riding I havent felt and impact since I put the Evol-x's on the Front.
-Extremely Happy with my Suspension set up.
musselman
I ran 40 to 50 psi in my floats for trail riding, they sat up nice and high but were not too stiff. I wouldn't go any higher than 60 psi unless you are jumping/snocross.
