mattyg1405
Ok I'm at the shop putting studs in one of the sleds and the tall nuts are not nylocs what color loctite do I use as I would assume you need to loctite them to prevent them loosening upthanjs um waiting on a few answers I don't know why I doubt myself sometimes
I would use blue. I cant see them backing off even with blue.mattyg1405 said:Ok I'm at the shop putting studs in one of the sleds and the tall nuts are not nylocs what color loctite do I use as I would assume you need to loctite them to prevent them loosening upthanjs um waiting on a few answers I don't know why I doubt myself sometimes
mattyg1405
Its a restud so the track is already squished where the studs go... So I guess I'll just use blue and tighten em down do I have to actually torque em????
valin
No, you do not have to don't torque them.
mattyg1405
Yeah and stupid me says right in the package Red loctite thanks guys
If you use red be prepared to cut them off next time as that stuff is a bear to break loose.
staggs65
i use red on just about everything, never had any probs getting bolts undone with red, all you need is a drop
