Picked up some RSI bars that are hooked at the ends... cant get the throttle assembly on. Does it come apart? It seems like it is not to be split... Any suggestions? Aftermarket assembly? What have you done? Thanks, John
1995vmax500le
i just had this same problem with my viper as i put on the 07 apex bars with hooked ends. i ended up making a new throttle block. i just have to get a new kill switch that well mount independently of the throttle block. i dont know if you can do that or if you could buy an aftermarket piece??
Thumper1
get RSI bars that aren't hooked at the end. then just add RSI bar ends after you get the controls on.
cause otherwise you are kinda stuck
SRXSRULE2
Can you not split the stock throttle block in half?
I had it appart and couldnt figure out how to split it... Seems like a mold and another piece are bound together. I may just return the bars for the other pair and add the ends, i was hoping to find a nice aftermarket assembly and keep the bars. Any more thoughts i am listening. THANKS
