What studs are you running in your SRX?
I have just installed 144 mack 1.075's they seem as good if not better than the woodys in my old apex. I have no miles on them yet but just by compareing the two i like them. I guess we will see. fyi the 1.075 macks are as long as most 1.175's in the other brands i compared them too.
Im not studded yet but i plan on 144 down the middle. Not sure if i wanna go with 1.075 Or 1.175. I will be using Woody studs with aluminum backers. I will probably go with the 1.075 so im not worrying as much as i would if i ran the 1.175's. Your SRX came factory with tunnel protectors and a front heat X-changer protector. Might wanna be safe and buy a protector for the rear heat X-changer as well.
i would steer you away from stud boys unless you can get them cheap, cause you are going to be replacing them faster. woodys have proven to be more durable, even their cheap studs are more durable than the stud boys.
Yes I would have to agree the Studboy Studs are not what their made out to be. Stick with Woodys...
