Rebuilding viper 5000 miles pistons look good, do i buy pistons or just rings?
Concept Carbon
check to see if they are in spec I would say there probably not.
rx1jim
Have them measured to see if the critical dimensions are still within the specs.. Post the measurements on this forum along with pictures of the pistons. I am sure the engine builders will advise you based on the info. you post. If the pistons measure within specs and show no signs of scoring, then I would reuse them for another 3000 miles.
TopGunnSrx
IMHO If you're this far into it just replace them.
The bearings take a beating too. Measure all the parts.
staggs65
i'd definately check your specs, but 5000 miles isn't alot, i bet your still in spec, but then again i blow @ gambling
rx1jim
Definitely measure the pistons and check them over carefully. Re use them if they are within the specs......the new pistons from Yamaha are about $140 each!!!!! I am about to rebuild the topend of an SRX engine with 13,000 miles. I have run Amsoil synthetic oil in the engine since the 2nd tank of oil. If the pistons are within spec., I am going to reuse them.
mattyg1405
man these yamahas run.... my expierience in the water is this i have a kwasaki zxi 1100 and a yamaha gp1200 r , never had them apart ever!!!! my dad has 2 sea doos xp's and they both popped motors!!! i hope my srx holds up like the marine tripples from yamaha
grapeape
Im going to help a buddy and do the top end on his srx with at least 8k on it. It will be getting pistons, as the srx pistons have been know to crack at the skirt and drop into the case. Im not sure if the Viper has any issues with that or not.
mopar1rules
grapeape said:Im going to help a buddy and do the top end on his srx with at least 8k on it. It will be getting pistons, as the srx pistons have been know to crack at the skirt and drop into the case. Im not sure if the Viper has any issues with that or not.
never heard of srx pistons having issues. anyone know the difference between the srx pistons and the viper pistons? boost port in different location? i never measured/inspected each one to see any differences. just know the part #'s aren't the same.
mopar1rules said:never heard of srx pistons having issues. anyone know the difference between the srx pistons and the viper pistons? boost port in different location? i never measured/inspected each one to see any differences. just know the part #'s aren't the same.
u must be right about boost port if they are not same parts number
