installation of m10 suspension on 95 vmax le
mattpolcyn
Millersburg, Ohio
I have two 95 vmax LEs and two m10 suspensions from skidoos. How do I go about mounting these on my sleds. The mounting kits are 225.00 each through fast, is there any way i can do this with out having to dish out all that money on the kits. Thanks
I am sure there is a way but by the time you put money into it and the hassle your better off buying the kit. I have a m-10 under a 94 vmax that I bought with it installed. The kit has 2 plates that go inside the tunnel and really add strength to it. It also takes up the gap for the cross shafts between the two sides. I am about to tear mine out and extend it out to 136in.
Thanks I guess I'll just break down and buy one kit to start with and see if can make sense out of it enough to install the other one without the other kit or not. Thanks
