mikeast
Anyone have any ides for upgrading clutching? running Aaen pipes on a 1998 srx its fresh rebuild, i rejetted to Aaen specs , any info would be helpfull.Combo trail / mountain , 225 pound rider, max be at would be 3000 ft
harness racer
what is aaen jetting specs ?
Any of the SRX clutching specs should work with the Aaens as they don't seem to build any noticeable HP increase that would require major clutching changes.
Some suggestions:
-because you are running "Off Trail" I would try a little lower gearing then stock like 22/38 or even 22/39[especially because its a 98 with higher gearing then the 2000-2002]
-I have found Team secondaries to be great especially off trail but then you will be into pretty well a total clutching recalibration
JMO
Some suggestions:
JMO
