I just took out my stock silencer and replaced it with an SLP can. I've got a few questions that I need help with...
1. I had to take out the rubber piece in the outlet hole in the plastic to fit it in. The new outlet pipe fills this entire hole. Will this melt the plastic around it without that rubber insert?
2. It leaks at the inlet of the can....the springs dont seem like they are quite as tight as they were with the stock one....do I need a new gasket or tighter springs?
3. This hopefully doesnt relate to the can but....last year my check engine light came on probably abotu 5-6 times and stayed on for just a few minutes and went off on its own. It did that a few times and never stayed on so I never got it checked out. When I started it up this year after putting the SLP can in, the oil light went on. its full of oil. I dont know if this is going to just turn off again like it did last year or if i should get it checked out. Anyone have any similar problems like this
Thanks for reading all that!
