Torque wrench question....
Nicko
Argentino Loco
Mound, Minnesota
Well I'm buying one......Not the $ 400 one.
Most likelly is only going to be used on the sled.....So the question is wich one to get...I was thinking a Craftsman then the have, mikrotork, digitork, shititork....I don't know, 25-250 ft lb or 15-75 or 5-80 or 20-150....wich one I wil use the most...I just think the 20-150 ft lbs will do but not sure if any of the yammy motor bolts, nuts etc go over 150ft lbs........
Any help comments will be great....Other brands ?????? I will like but can't justify a Snap-on or S-K....
Nick
sears had a big sale on black friday last year - they were cheap! Like $40 off - I'd hold off if you can.
xs
I would do the 5-80 one as most of your range is covered, 7.2 is a popular torque spec, and anything over 80 is past lug nut tight, and the only things I have seen that tight as of late is a rear axle on motorcycles (100+) and 4 stroke heads which are 14 lb, 22 lb, then 180* which really becomes a index mark vs a torque spec.
Ditto on the craftsman. Very good value for the money. Those others are for professional wrench spinners who need the bling factor!
Get the 5-80 it'll be more sensitive down low thats what i use, not many bolts on the yammie will no be over 80.
sorry to barge in here, but i guess it's in sort of same category. What torque do you use on all of the crank house bolts, and also the bolts for the top?
-Ray
-Ray
Are you looking for specs i would say?
Most torque wrenches are only accurate in the top 10 or 20% of their torque range.
But, for what it is worth, It mostly use the 5-80 on the sled.
Clicker style, dial, or electronic beep style are personal preferance.
I use a dial style with a tattle tale for really light uses ~ up to 10 pounds. otherwise I have one that Beeps when it gets to a predetermined torque setting.
