gbic1
Shim, weights rivots, Part #s
This will be my first try at clutching and I am doing Turks set up for my 98 700sx. I am trying to order the weights 4.5 and 3.1 but what part numbers are these? I did a search but did not find what I needed.
@@@@ Now need shim part numbers. Cant find them on Yamaha parts page.####
from my rivet box: 4.5 pt# 90261-06033-00. 3.1 pt# 90261-06019-00. all the info you need on weights, rollers, rivets, etc are in the tech section. not the tech on forums side, but the tech off the homepage. i encourage you to take a trip in there as it holds tons of usefull information.
gbic1
I guess I missed that section. That is what I needed. Thanks!
thanks crew, i knew someone would post the link.
