Crank Discoloring
lords88
Moscow & Arco Idaho
I have a 2000 MM crank that was welded and trued back in 2004 by Unionbay. When I dissassembled the engine for porting I noticed that my crank on the PTO and Center have a heat discoloring down by the bearings. All of the bearings are tight and everything else looks great. Is this normal, Or do i have a problem.
None of the welded cranks I've seen have been discolored that bad. I'd be calling union bay in the morning to see what they have to say.
I found a thread on this forum that said that that coloring was normal, something about the may the crank is assembled? Anybody shed some light on that?
