Took out skid, lower center shock mount bar bolt had sheared on left rail along with breaking off ear on left rail. Right side is fine and didn't hit track. However, the inside of left rail now has been worn down were the shock mount bar rubbed. Thinking of just swapping rails from left to right putting the bad spot on the outside. Will this be fine and do you just re-rivet rear axle adjusters back in place with steel rivets?
staggs65
if you decide you want to replace it i'm swapping out to a sc10-111 and will be parting out my no-action, just pm me if ur interested
jeff
jeff
The left and right rails are different... There is a space on the inside up in front where the front control arm bolts into.. The INSIDE of the left is opposite the inside of the right and they aren't interchangable...
