On BV thread about updating and tightening proaction skid, there are solid bushing for the W arm instead of nylon listed for update. Do you need to get a new upper shaft for the W arm or can you install the solid bushings on the old shaft? The old shaft and nylon bushings were still greased and seem fine but the new solid bushings would definitely hold the grease better.
OnDaTrail
I made solid bushings for mine. Just measure what you have there and make to fit. It does really tighten things up. For the lower bushings, I ordered a set of plastiic shim stock from mscdirect. You can cut it with scissors or a shear and just select which thickness tightens your bushings up.
