Air box removal and crab removal on phazer 2
Rev800doo
NY
Hello....how do I remove the air box and the carbs on a Phazer 2?
I need to get the carbs out to clean them...are there any tips ? Do I need to remove the air box?
you need to loosen the cover over the gas tank (in front of the seat) to get the air box out to get the carbs out. (Clean carbs won't fix your spark problem.)
thanks...I know the clean carbs won't fix the spark problem...just another thing that needs to be done....thanks for the tip on the air box
