I have a 2000 700 Venture that I am about to change the track on so while it is apart I am going to change the drive axle bearings. In Canada through Yamaha the two bearings are worth $100.00 dollars plus taxes CCCCrazy! Does anybody know the NTN numbers for these bearings preferably the Blue Seal ones, I don't know if there any beter or not but people say they are.....Thanks.Glenn
OnDaTrail
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
If you need the bearing on the speedo side part #93306-20589 shipped to you house in Canada it is $43.00. send me a p.m. if you need. The part is Yamaha OEM.
Bruce
Bruce
CdnSxR6
royal distributing has them too.
crewchief47
Lifetime Member
And for the love of ***, put some fresh grease in there a couple times a season. If you're careful, you can remove the seal with a dentist pic or small screwdriver and clean and re-lube the bearing. Others just slip a grease needle under the seal and lube in that manor.
Skip all of that if you already do that and it was just time to replace.
