'02 SRX motor mount torque specs needed
Boomer
Lifetime Member
Inver Grove Heights, MN
I'm hoping that someone would let me know how tight I need to torque down the front and rear motor mount bolts on a '02 SRX. :dunno:
Doing some work on the sleds this weekend and would really appreciate anyone's help. ;)!
Thanks,
Booomer
17mm socket size=40 ft lbs,
19mm socket size=61 ft lbs, got these numbers out of the rear of the manual for general specs. T
From my '00 manual...Engine bracket and frame 36ft/lb... engine rear bracket(right/centre) 24ft/lb...engine rear bracket(left) 17ft/lb...engine rear bracket(left) connecting arm 29ft/lb...engine front bracket and damper 29ft/lb. Hope thats what you were looking for!!!
