How high can you rise MM bars, with Extensions?
MountainRx1
Wisconsin
Hello, I am wondering how high you can take the bars on a 02 MM, and have all the electrical reach. I will be buying cables, and brake line, so the only limiting factor will be the wiring. This is my buddy's sled, and he's a really big guy, so we need the bars as high as possible.
Thanks..
i put a 6 inch on my MM700 and i made connectors to extend my wires, this is very easy thing to do, pull the plugs apart, i think there is 2 types of connectors that will fit on the prongs of the plugs that you unplug to extend. make the wires about 8 inches long and tape the wires to the plug so they cant pull out, it worked for me...
Do you have any pics of this?
I just cut the ends off one side, extended the wires with a little wire, solder, and heat shrink, plugged the ends back together, and had extended wires.
Buddy of mine did the same thing, but he did his so that the plugs are all under the plastics now. No plugs by the bars. Really cleans up the look when running aftermarket bars.
