Does this look right?
burg226
Canada
The stabilizer bar looks completely upside down. Wouldn't this totally affect the suspension? Seems like its hitting the under carriege which in turn would lessen the action of the suspension. How would i reverse this back? I loosened the bolt on the ski, removed it but the arm doesn't seem to wanna rotate. Any ideas?
no it is real rare that it happens but it has flipped over causing you to lose most if not all of your travel on the left side of your sled. unbolt it and flip the sway bar around
Jeff
If it is flipped over on the left side it should have flipped over on the right side also! You may have to unbolt both sides to get it to go back to normal
Awesome, see i only unbolted the one side and couldn't figure out why it wouldnt rotate. I'll try unbolting both sides and see what happens. Thanks for the tips.
