1998 SRX 700 Clutch set up what you think of this one?
VmaX 600
Minot, ND 58701
here is a clutch set up I gound on here for a 98 SRX let me know if its good and what else do you have for a clutch set up thats better.
8bu-00 weights, 4.5 rivet in tip only, .8 alum in heel hole,white maxx spring, 52/35 helix with green spring at 70-80 degrees, drop the gearing to 21/38, your gonna need very good traction, so I hope you have alot of studs, also, put the stock silencer back on, the aftermarkets slow them down.
