gravity worx cables
1995vmax500le
arnprior ontario canada
does anybody know how to set the oil cable adjustment on the extended length oil cable?? its not the same as the stock cable as it has a threaded adjuster and i need to know haw to get it set properly.
I'm needing a little help here as well. The service manual has you measure the cable distance exposed when you slide the sheath back and to move the adjuster to get the correct length. Even with the cable disconnected from the throttle lever and both the inline adjuster all the way in there isn't 20mm of freeplay.
Extended cable, its not the Gravity Worx from above but it doesn't separate like the stock one
hey so the inline cable adjuster is set to have a 21mm gap or the adjuster down at the oil pump?? i need pics lol got so much on the go with the sled its hard to keep track
and as far as i have seen my oil pump does not have the closed and fully open indents on the pump lever
