AKMM
My son nailed a rock last year and bent the trailing arm and radius rods on the right side. I am retiring this sled to be used as a tow sled to run stuff across the lake to my cabin. I was thinking it might be a good time to widen it out and make it a little more stable on the flat stuff.
My question is what parts do I need from a trail sled to make this happen?
Does everything have to be switched out? Trailing arms, radius rods, shocks etc??
Thanks in advance.
Thanks in advance.
grapeape
radius rods, tie rods. I have a set of tie rods cheap.
AKMM
So I only need 1 trailing arm, radius and tie rods?
Which sleds should I be looking at for parts?
SX, SRX, VMax???
SX, SRX, VMax???
srx would have a 40.9" ski stance, sx and vmax would be at 42.1" mtn max came in 38.6".
sockeyerun
Test Dummy
SX and Vmax are what you want. The shocks are also longer so you will also need to be replaced. You can use the KYB's (rebuildable) off either the SX, Vmax or a Viper (not mtn Viper). They are also a lot better shock than came on that sled, unless you have Olins.
AKMM
Thanks guys. The search begins...
Apher
I have a complete set of Radius rods and stearing rods. All you will need is the shocks. I ran them on my '97 M-max. I hit a rock and bent one side. I went back to stock so I could ride. I order new rods and have not even put them on. I will get some pics tonight and post them for you.
Apher
Here are the pics of the radius and stearing rods. They are stock rods off of a V-max model.
The blue rod is a stock 2000 rod. just to show the length differance.
I was thinking $80 + shipping.
Let me know what you think.
AKMM
Sorry man.. I actually jumped the gun and bought a SRX set of Ebay before I read the posts that these would be wider.
If they dont work out I will let you know.
Thanks for trying to help out.
