I am working on a 97 xtc 600 for a friend, and found that the weights (8ch) are worn out from having bad rollers. What is a good starting point for clutching this sled. What spring and weights should I try. looking for an agressive holeshot.
tedgoesfast
straightline pin kit about 50.5 grams of weight use cat weights and stock spring with 2 shims for engagment that should be close
mopar1rules
turks clutch setup:
8CA weights, w/2.4g each hole, stock primary spring, 50/44 helix, and green spring @ 60....i believe.
