We all see the threads about PV cleaning, but how about changing coolant on an srx?
1) Where is that drain bolt? Is it #15 or am I lost?
http://fiche.worldofpowersports.com/wps/Yamaha_OEM/YamahaSnow.asp?Type=13&A=276&B=3
2) How do you get ALL of the coolant out before refilling it?
staggs65
yeah that bolt drains it down below the head level, not totally sure how much it leaves below that, but i'll know tuesday when i get my clutch puller and can get the bottom end out of the sled, someone else will surely post before then
staggs65
meant below cylinder level not head sorry
search is your friend.....norwegian said:We all see the threads about PV cleaning, but how about changing coolant on an srx?
http://www.totallyamaha.net/forums/showpost.php?p=229250&postcount=13
Thanks, but it still doesn't explain how to get rid of all the old coolant
well you'll still have a little in nothing you can do,what i do is use shop air and blow from the bleed hole in the rear cooler wile the front drain plug is out it gets most out that way.norwegian said:Thanks, but it still doesn't explain how to get rid of all the old coolant
