viper steve
went to the dealer to pick up come 15.6mm rollers and they want 47 bucks a peice for them!!! WTF is there anywhere else i can buy these size rollers for a more afforadable price?
Are you replacing them or changing size
bluehammer
Is that for 8mm or 9mm pin? I have both.
viper steve
just changing them from the stock 14mm. not sure what size pins those are what even comes stock in a sxviper
May I ask why you are changing from the stock 14mm?
Here you should be able to see the price for some rollers for the rx1. Maybe not the same (9 mm vs 8 mm) but it will give you a price range:
http://fiche.worldofpowersports.com/wps/Yamaha_OEM/YamahaSnow.asp?Type=13&A=288&B=16
steve..I PM'd you some good info.
