TREBB
Viper clutching in a 700sx
Need some help from some of the clutching gearing gurus… sled info 97 sx 700 (red head) stock
The previous owner put an 02 700 viper primary and secondary clutch …( I think) primary weights 8EK spring YWY …secondary 8BV70 with a red or pink spring I had a hard time to tell not a lot of paint left on it.
Is this set-up worth keeping or should I change to one of the set-ups with the stock weights that turk recommends or can I work with what I have? And if I can work with this set-up is the stock gearing going to work?
thanks
thanks
