A bud of mine that I sled with called me the other day to ask if he could use my clutch puller bolt to lend a friend of his so he could remove his clutch from his 03 RX 1.Well of course I lent it to him and upon asking what type of work the other guy was doing to his clutch my bud tells me that the guy has a groove in the clutch,what part we're not sure,and he was sending it out to be machined smooth again.My bud and I were speculating that the groove is in one of the sheaves and was no doubt cause by an improper belt used or a piece of debris getting caught between the belt and sheave.This is only speculation as neither I or my bud has seen the clutch.Well I will be the first to admit I don't know much about a lot of things but one thing I do know is that if the groove is bad enough I certainly wouldn't be machining it out I'd be replacing the grooved part,especially on a 4 stroke sled.Can you imagine having a primary with a sheave machined thinner on one of these torque monsters?To me this is a clutch explosion waiting to happen and I told my bud to tell this other guy,and I'm not the first one to do so,not to do it replace the defective part.
Just thought I'd pass this on for your reading entertainment.
blue missile
cant imagine any other place on a clutch that if it had a grove it would matter. by all means do not make the sheeves thinner these can be bought and replaced if taking to a machine shop a replacement sheeve cant be much more in price.
