All Balls racing bearings
fourbarrel
VIP Lifetime Member
Has anyone used any of the products offered by All Balls Racing?Royal Distributing offers them and they have kits listed as everything offered to do an entire shaft,ie jackshaft,from the bearings to the seals and retaining rings if necessary.
bluemonster1 said:
haven't heard of it..is it in the catalog??
The catalog has them starting on page 124 and they are listed as Snowmobile drivetrain bearings and seal kits.I'm just curious if they are a good product,I usually order NTN bearings from Royal and I need to replace my jackshaft bearing this season I just figured I'd give All Balls stuff a try if others have used them with good luck.
I've heard of a lot of guys running the All Balls bearings on the Raptor Forum, thats what I am using in my rear axle, good stuff, but I only have 1 season of flat track racing on the wheeler so I cant comment on longevity...
I use them and while I did not tear one apart to check tolerances they seem to last just fine. You can get kits for Yamaha axles aftermarket at any place that orders stuff through Marshall Distributing. Worth a look if you need bearings for both ends of an axle.
I've run them years in my dirt bikes with good success and I'm using their driveshaft kit on my MM now with no complaints.
sold the heck out of them last year seem like quality bearings especially for the older sleds that need jacl shaft pillow block bearings ...........at a good price instead of the overpriced factroy bearings ............must add that we have been using them in out vintage race sleds for 2 seasons now and no problems ...........trust me when i say if there was a problem with them we would have found it by now these machines take a good beating every year .............worse than most tral riders
