84 Phazer Carb Synchronization
Frozen Tows
Brainerd Minnesota
To start, I'm brand new to TY forums. Thanks for the great site!
I cleaned the carbs on our 1984 Phazer. They were in really bad shape. Now squeaky clean!
Carbs were out of sync, so I dialed them in to open at the same time. Thing is, now at WOT, one butterfly looks like it’s going past WOT.
In the idle position both butterflies are the same. Move to WOT and PTO side seems to hyperextend towards closing again.
It's not much, but shouldn't both operate the same? That's why is called Synchronization, right?
ok, winged it. Set them up in synch on the bottom. I figured this little guy is probably not going to see a lot of WOT. Runs little new! Idle at 1500rpm smooth as silk. Well, as smooth as a 84 Phazer can be. Cheers.
