jasonlmrx
so i baught a 2" paddle track 136" im installing rail extensions on my crappy proaction skid and i just want to make this simple and all so im goin to ask a few questions
i want to run my 2" paddle so i have to change to 8t drivers right? i could go with antiratchet wile im at it im goin to keep my stock jackshaft if it is possible i am able to press them on or whatever i have to do so i am on the right track right? that is my problem that im worried about i have the stock 9t driver on and i have to go to 8t wich is simple and with my 8t driver i should be able to run 2"..
Thanks alot for the help in advance
Thanks Jason
Thanks Jason
grapeape
Yes 8tooth drivers, and i would go with extroverts, if you have front heat exchanger protectors, take them out, as it is a tight fit already. I have an extra sx drive axle if it helps.
jasonlmrx
any link to where i could buy these extroverts? i would like to check them out
Thanks for the advice.
Jason.
Jason.
check with bruce at cb performance, on this site, and a site sponsor. simple as pressing the old drivers off and doing some math and pressing the new ones on. the antiratchets are placed at different locations on the shaft then the stock drivers.
jasonlmrx
yea the antiratchet have to be pressed so they fit in the windows on the track im guessing. right?
jasonlmrx
does this change the pitch because i was looking at some drivers and im guessing i the 8t driver has a diffrent pitch or if because the driver is smaller the pitch changed could somone show me exactly what driver i need i want an antiratchet 8t driver .. if i could get one with the jackshaft and all already pressed on it would be nice..
Thanks Jason
Thanks Jason
WNYViper
-You would go with whatever pitch your track is
-Stock Yammi pitch is 2.52
-The pitch is the distance from the center of the window to the center of the next window on the track... it stayed the same if you go anywhere from 10 tooth to 7 tooth drivers, it is the diameter of the driver wheel that changes to maintain the correct pitch
If I look I can find the measurement for the location of the Wahl drivers. Got them out in the garage somewhere.
WNYViper
Oh, and make sure you check clearance on the anti-ratchet drivers and your skids range of motion, the stock plastic anti-stab snubbers come very close to the anti-ratchet drivers and in some cases you need to trim the actual rails for clearance and buy one of SLP's anti-stab wheel kits to mount on the rails...
http://www.startinglineproducts.com/catalog.cfm?pageID=detail&catalogID=5&catID=36&productID=927
jasonlmrx
alright guy's ive gather enought information to go on with this mod i will be starting has soon has my materiel comes in then il be asking more questions
Thanks Jason
Thanks Jason
jasonlmrx
anyone know where i could buy a brand new jackshaft with 2 8t antiratchet drivers already installed on? or they dont sell anywhere?
Thanks Jason
Thanks Jason
www.outdoorsupplyonline.com has drivers
I have a diagram showing where to place the drivers on the shaft for a 2002 Mountain Max, should be the same as yours. If you want it PM me your E-Mail addy.
jasonlmrx
no thanks on thos diagram's ive just found out my friend that works at the local dealer will get them put on for me
Thanks Jason
Thanks Jason
