Need help removing chain case assy
ualav8
Watersmeet, MI
I have the cover, gears, and chain out. i removed2 long bolts from the side and one nut off the top right side. the case back wont budge! am i missing a bolt?? should i pry it off somehow? where should i pry it?
thanks
Your missing bolts somewhere feel around i think there are some hard to get on the bottom of it. Do not pry on it or ull be buying a new case, when all the bolts are out it should practically fall off. If youre not sure check the fiche on yamahas site or portyamahas site easy tool to use before you start prying when you still have a bolt in.
