head gasket mod
sxviper32
Valparaiso, Indiana
i read in the tech section about the sx gasket modification, but i could't find anything on head gasket mods for a 01 srx 700. anybody know how to do it, or is it the same as the sx ( remove half of the gasket) ? thanks...
There is no head gasket in the SRX. If you want to raise compression you must cut the heads down. I don,t recommend cutting the heads for a 00-02 SRX.
You can also play with the base gaskets.....Its going to effect compression and port timing. Thats just what Ive heard....I only run stock sleds ;) ===SRXSRULE===
