Yamasquaw
- Jan 8, 2005
SC 10 III install (with pics now)
I read all posts about installing an sc10 III and now have all the parts i need to do the install. I picked up some drop brackets from cbperformance and have a dilema here. My donar sled shows 6 and 3/8" to the rear mount. When using the drop brackets my rear bolt will be 8 and 1/4".Thats an inch and seven eigths difference. My question here is do i drop my front mount 1 and 7/8" also, too keep the same level of the suspension? Attached is my donar sled info...2001 MX-ZX 700. I read all posts and could not find any info on this subject for sc 10III's, just guys dropping the edge skid 7/8".
I don't think you have to drop it quite that far,,, but the upper wheels on the doo skid are smaller than the yamahas....
bluewho
I would not drop the front mount.If you are wanting to lift the rear of sled dropping the front mounts for the suspention will only cause the rails to have more weight on them.It could be levaled out by pulling up the straps but that is defeating the purpose no?
Why not put the drop brackets on bolt the skid in and look were the front axle wants to sit to keep the skid flat on the ground.
Yamasquaw
- Jan 8, 2005
Mounted skid and worked good. just waiting for bearings , then can install drivers and new 1.5" ripsaw.
bluewho
Did you go with the drop brackets?
bluewho
Is there a problem?
Did you drop the front to match the drop brackets?
Yamasquaw
- Jan 8, 2005
I didn't have to drop the front brackets at all. I mounted the rear first as blue said then compressed suspension to 24" and swung it up into tunnel till the rails were level with floor. and it worked out to my measurements that i had transferred inside from the driveshaft. I will post photos when i get it all back together, just waiting on the 2 collars that slide on the jackshaft and driveshaft that fit into oil seals. They were pitted up pretty bad so i figured since i was doing all new driveline bearings, may as well put new collars also. good for another 12,000 + km's!!
Yamasquaw
- Jan 8, 2005
Heres the final product. Just got a call saying that other chaincase parts are in. Just in time seeing that the snow is falling!! Couple little things to finish up on it then bag it.
stretchSXV
Dam that looks awesome with that rev skid in there. I might dump my m-10 and go that way
bluewho
You used the middle brackets instead of the front i see.Good job you will need a longer flap.
Yamasquaw
- Jan 8, 2005
No. i use the fronts. I cut them down so they fit on top of the heat exchanger. I made the front mount plates on the outside outta some aluminium i had kicking around. and seeing i had longer multigrip rivets i could afford adding some strength there.
I'm going to doo the same mod tommorrow, it's an 2000 srx and I have a sc10 III. Just have a few question... how did you locate the front suspension hole? the distance for the two holes should be 24 1/8?? your drop brackets for the rear are flat, I mean are they L shape to hold the foot rails??? If you would have anymore tips or hints that would be greatly appreciated... thank you
staggs65
racingx check this thread out, doesn't have info on drop brackets, but good info for installing sc10III
http://www.totallyamaha.net/forums/showthread.php?t=43641
thank you for the link, that is i'm looking for...
thank you guys the for help and tips, here is the final products... didn't use drop brackets, we'll see how it works.. just need some snow to try it out. I had to use 3 washers on each side on the front mount inside of the tunnel, the tunnel was a little bit wider then the sc 10 III was.
bluewho
How long did it take you ....a couple of hours?
by the time i dicifered the instruction, which were fantastic, I followed what you had done on yours to the 'T', got needed some parts on the doo dealership so made a trip out there, less then a day. Used metal pop rivets(stronger) instead of the aluminum ones. the rear of the suspension did tip up a bit, but once on snow it should be fine, pulled the limiter strap in like 3 notches for a starting point.
