power loss
vintagemuscle said:
will a viper single pipe work on my srx 700 engine? and if it will what kind of power would i lose?
crazzy probabaly will loose about 25hp also fiber pipes are designed for a viper its porting is different, you could modify it to work thow although I dont no why anyone would want to
you'll either need make a new manifold, so it mounts up to the srx cylinders, or get some viper cylinders and then manifold will bolt right up.
vintagemuscle said:
i'm putting a srx 700 into my 81 srx chassis. and i'm not sure if i'll be able to squeeze the triple pipes in. so i'm looking for options in case
Ha! I love it. Good luck. I looked at doing the same thing in a '91 Vmax. There is no way you can fit those pipes in there. Mag side carb would also be an issue, but that's do-able........probably have to ditch the rad. Perhaps you can have a custom set of pipes built with one out the left side somehow, but there's no way to run 3 out the right side. You can do a single with some work, but u'll kill the hp. I put some thought into it, and if I were to do it, I'd go with a big twin instead of a triple. Too bad you'd have to switch to one of the other 3 brands for the engine, but that's the way I would go. That SRX would be mean with 160 hp :)
