dirtjumper895
Will a Primary clutch puller for a Yamaha Bravo work on the primary on my 04 SX Viper? Not sure if the threads are anwhere near the same?
all you can do is try I guess.
take the clutch bolts out from both sleds and see if they match up.Try one into the other and if they thread in,at least you know they are threaded the same.
vintagemuscle
yes, they're both supposed to be 18mmX1.5mm.
