secondary end play
mike12820
Lake George NY
Diving into clutch tuning for the 1st time, going to the famed Turk setup. I have question about the secondary end play, the whole unit will slide back and forth on the shaft. I measured .083" with my feelers between the secondary/3 washers and the big washer holding the sleeve in. I searched and saw 1 post that said 1-2mm is normal, looking to confirm. Didn't see this measurement in the supplement .pdf manual I have. Is there a place I could have looked up this info myself?
2001 SX700R
Thanks,
Mike
what you dont want is anything less than that. you want the secondary to find its own center. if there is no play or very little.. you could have belt problems and or clutch problems!
