I was reading another thread about the decals changing through the years- did the hoods shape change as well? Like could you remove the decals on a 98 and put the decals from an 02 on? Also I like the blue bottoms better than the black. Can those be swapped out as well?
The hoods stayed the same besides the headlight change so yes you could swap the decals and as for the belly pan I guess you could do that too...jay-s said:I was reading another thread about the decals changing through the years- did the hoods shape change as well? Like could you remove the decals on a 98 and put the decals from an 02 on? Also I like the blue bottoms better than the black. Can those be swapped out as well?
staggs65
i wish i had the blacks, i want to black out my whole sled in the worst way, but i'd have to much plastic to change, not to mention buying new skisAlso I like the blue bottoms better than the black
