fortress
Hi guys
what'S the trick to remove and replace rivet in the weigth??
can i do it with simple tool?
What bolts and nuts do you use ? Where can I get some? I am sick of drilling and ordering rivetsWhammy said:Then use bolts with jam nuts to tune & run,,, drilling those things out bits...........
Whammy said:Well I was introduced to them when ordering rivets for clutch weights through Rusty at Hauck,, and he sent me a set,,,,, bolts & nuts that was dead on at 4.5g ....ever since have supplied my self through any nicely supplied hardware store..... need those jam nuts though.. Half a drop of removable loctite and your set... can use washers to add weight or grind on bolt,, Take gram scale with you, come up with what you need........
