on1_wheel
i just purchasd a 2000 SRX...wanted one for a long time, finally got it. Gonna have a few questions as I'm checking it outand hope you guys can help... first of all, on the PTO side of the engine on the coolant line to the head, whats the on/off switch for and should it be in the OFF position?? (mine is)
also, mine has an aftermarket can..guy i bought it off of didn't tell me, trying to figure out what make it is, can't find any ID on it, all i can say is its a round cylindrical can?? any ideas..i know trhats pretty vague..
kirk700 srx
That switch is the shut off for your heated carbs I leave mine on all the time
kirk700 srx
Also it sounds like a bender can they are usually round cylindrical
livewire_101proof
people racing usually will turn the valve off to run cooler, trail riders usually will leave it turned on. Benders trail can is round, not sure about others, race cans usually are the tripple trumpet style.
on1_wheel
thanks, any jetting changes needed for that can?? i haven't opened the carbs yet, don't know what's in there yet??
on1_wheel said:thanks, any jetting changes needed for that can?? i haven't opened the carbs yet, don't know what's in there yet??
No, the can will not effect your jetting.
Unless it's cold as hell out or your busten pow keep them OFF,id ditch the can and put the stocker back on,you could ...be loosing power from that fart can.
staggs65
x2 on damans post
also clean them carbs and clean and adjust the power valves, do a search and you'll find more info than you know what to do with
yeah i know i'm a
yeah i know i'm a
No such thing staggs when your trying to help someone out,keep up the good work thats why were all here.staggs65 said:yeah i know i'm a![]()
fart can...
I got one on my SXR?)) and it smells sweet..lolllllll
tntmax
pull chain case cover off and clean well . inspect chain, sprockets and bearings, tighten chain to specs, put cover on and put amsoil synthetic oil in and you will have a good piece of mind on your drivetrain
on1_wheel
thanks guys, i intend on going over that sled top to bottom, think I'll live with the can though...(it kinda sounds sweet i think..not too loud either) rather spend some money on clutching than a stock can. I'm used to much slower sleds so I'm sure I'll think this thing is a rocket even if I am dropping a hp or two at the can.
installing 144 studs today!!
on1_wheel
oh, did I mention it only has 4800 kms?? and its snowing here today!!
staggs65
oh sure, rub it inand its snowing here today!!
kirk700 srx
We Already have 2 feet of snow and all lakes are frozen up here in Labrador!!on1_wheel said:oh, did I mention it only has 4800 kms?? and its snowing here today!!
007redline
tntmax said:pull chain case cover off and clean well . inspect chain, sprockets and bearings, tighten chain to specs, put cover on and put amsoil synthetic oil in and you will have a good piece of mind on your drivetrain
+2 and inspect the power valves & clean them to make sure there not broke..and set the power valves... Keep cleaning them threw out the season...
on1_wheel
yepp, cleaned the valves today, they've NEVER been done...and did the chaincase, going through the entire sled top to bottom, gonna take me a week or so, but it'll be worth it!!
on1_wheel said:yepp, cleaned the valves today, they've NEVER been done...and did the chaincase, going through the entire sled top to bottom, gonna take me a week or so, but it'll be worth it!!
It's a 2000 and the valves have never been cleaned???? Yikes, what did they look like...LoL.
