Bolting in RX1 Suspension into 2000 SRX
averagesleder
Niagara,Ontario,Canada
Bolting an RX1 Suspension into 2000 SRX
We're trying to put an RX1 Suspension into an SRX, the Suspension fits and the front 2 bolts are in. We can't get the back 4 bolts in because we can't lift the suspension in high enough to lineup the bolts with the holes.
Is there any special way to do this? Does the Track Tension have to be all the way loose?
Any suggestions or comments would help,
Thank you!
Yeah, loosen off the bolts on the end of the transfer rods and push the rear wheels/axle as far forward as possible. I start with the front axle, middle than rear.
Try turning the sled on its side. Put in the one bolt and turn on other side and repeat. So much easier than prying with the weight of the sled working against you.
all you do is loosen the transfer rods and then drop the sled down and put all of the weight on it and then it will be easy to line up the bolts. much better then lifting the sled. try it.
