whats good compression after rebuild srx
mikeast
bc, canada
should you wait till engine is broken in to worry about compression? just got rebuild done only at 100 110 cold hasnt been broken in yet shouldnt it be 125 range? hoping this is because rings are set yet
hey
gauges are all different..but after my rebuild on my 98 srx there was 121 psi
As long as there the same across the board...mine was all stock...compression should prob be between 119-125psi
