Offset rear axle kit in an SRX
Harvey
upstate NY
I just finished installing this in my SRX,It is the kit from performance engineering and machine that moves the axle forward and up so you can run 8 inch wheels on the rear of the sled.I think this kit will help the rolling resistance quite a bit but be forwarned if you buy one,its a pain in the butt to install in a yami.Looks quite trick with the aluminum 8 inch idler wheels.Looked like the install in the tech section in an M-10 was a much easier install.Any one else running this kit?-Harvey
its a pain to install in the m10 also but the worse part is trying to tighten it...you need a special crows foot wrench to get at the back nut...but damn nice once on :)
